跳转到主内容
The Asus Zen AiO Pro Z240IC is an all-in-one desktop computer known for its 4K, ultra high definition screen and one terabyte Hard Drive. With plenty of processing power and memory, the device received the PCMag Editors’ Choice award in 2015.
22 个问题 查看全部
Display not working after Motherboard Installation
I purchased a replacement motherboard (v 1.4) and have installed this according to the procedure shown in this guide. The motherboard powers on, the fan spins as it should but there is no display showing. I have tried reinstalling the RAM and re-booting but no luck . The display still does not show.
Does you have any suggestions? I am at a loss at the moment.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Its turned out to be a faulty motherboard. I bought a replacement from Alliexpress and it has worked perfectly. Got into the Bios 1st time round without an issue. We think that the graphics card on the old motherboard was the problem.
Thanks for all the help.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
If you haven’t done so already, look through the ifixit guide again and recheck all your ribbon cable connections.
Does your model have the HDMI port? If so try connecting to another monitor or TV to see if you get anything.
这个答案有帮助吗?
得分 1
2条评论:
I have checked all the ribbon connection cables. I have even tried connecting to another monitor. It is probably something simple but at the moment I can’t work it out.
完成的
So you see nothing on the screen, not even able to get into BIOS?
完成的
添加一条评论
添加你的答案
Manjinder 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 378
