跳转到主内容
加入维修社区 - 创建账户
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
Screen not responsive iPhone X
iPhone X screen not responsive but get notifications. did hard reset but no help. no drop, no water, or nothing just issue started. even no update. it happened about few month ago several time but start working its own and one time wont work and apple tech ask me to hard re boot so i did and worked. phone never droped
thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Even the warranty expires?
完成的
添加一条评论
3个答案
已选择的解决方案
Apple covers this in their service program, don’t try to repair this yourself.
这个答案有帮助吗?
得分 1
3条评论:
Even warranty expired
完成的
Yeah this is a special issue, look at their service programs.
完成的
Thank you checking now. Can you send a link if you have handy
完成的
添加一条评论
最有帮助的答案
It sounds like a damaged/defective screen to me. The repair costs on the X is quite high so you may want to drop by a repair shop to see if a replacement screen will solve the problem. If it doesn’t then it won’t really cost you anything as opposed to ordering a screen for yourself.
这个答案有帮助吗?
得分 1
添加一条评论
so i got it fixed. i knew the screen is good but probably conflict within two programs. i did hard restart several time no help. called apple and they said screen is bad and take it to best buy. so i decided to give a last try.
hold down up volume or down volume key WITH HOLDING POWER BUTTON, when it goes to power off, medical id and sos screen just
keep pushing any button until you see a window from bottom pop up, cancel , voice over and one other thing. just leave the device like this and let the battery drained, once the battery drained wait couple of hours and charge it through the computer port. i tried this with the wall charger and did not work.
i think issue was me unlocking with face id and same time attempted to unlock by sliding the bar up to unlock with the pass-code. no patience!!
moral of the story is, human is faster then technology.
good luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mohammad A Butt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 403
