跳转到主内容
加入维修社区 - 创建账户
Cellular version of Apple's 2nd generation iPad Air. Model A1567.
Air 2 Continuously Restarts
So I’ve got this customers iPad Air 2 here. He brought it in and said that it just keeps restarting. He said he took it to apple a couple of years ago and they told him the issue but he doesn’t remember what they wanted to replace. So my colleague suggests changing the battery, this fixes nothing. The iPad will sometimes come on if you hold down the power and home button , and will always come on as soon as it’s plugged into the wall or a laptop. After maybe 2-5 minutes, the iPad just turns off. Sometimes it’s still on when I long press the power button; but most of the time it’s just bootlooping. Other times if I unplug it and don’t touch it , it will say on for hours. Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Maybe it's just me, but I don't understand from your description if you replaced battery or not yet..
完成的
I apologize . Yes, he suggested changing the battery. He did it, and the issue persists.
完成的
添加一条评论
1个答案
Sounds like it could be a logic board issue. I would also check to make sure all the of screen connectors are properly inserted first. If they are fine and you have swapped the battery and it is still experiencing the same issues either the logic board could have a defect or the pads where the battery contacts the board isn’t getting a solid connection. If you have a spare board lying around it wouldn’t hurt to swap it. Issues like these are hard to diagnose because if you are like me you don’t want to blow $100+ on a part that might or might not fix the issue.
这个答案有帮助吗?
得分 0
2条评论:
I’ve checked the connection on the screen and board and all are fine. I wish I had a spare board but I don’t. The customer was very convinced that apple told him changing a part out would fix this. I don’t want to but maybe plug and play?
完成的
If you have already replaced the battery it should have enough juice to run the iPad out of the box. It's pretty rare from what I've seen that a battery doesn't come charged. I feel like the only thing it could be would have to be the logic board. I'm almost ruling out the charging port because that wouldn't make the iPad turn of if it has enough charge on the battery. Try and see if there is any physical damage on the board.
完成的
添加一条评论
添加你的答案
David B 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 200
