跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Why is my iPhone stuck in 1% and restarting itself every few minutes?
So i wake up this morning and i dropped my iphone 7 from the bed, i went back to sleep and when i wake up my phone was on 1%,I tried charging it but it shows 3% or 5% and it restart itself every few minutes and the apple logo appears 2 times and it shows again 1%,the battery health shows "the iphone is unable to determine battery health", it was 84% before this happened.I tried to charge it after that and it go to 100% directly before to restart and when it restart it's again 1%.
i changed my screen 2 months ago.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hmm if you changed your screen, did you replace the plate over the battery? Open it up and disconnect and reconnect it. Maybe it just jostled apart during the fall. Try that, and let me know how it goes :)
这个答案有帮助吗?
得分 1
4条评论:
it wasn't me who changed i took my phone to a repair shop. but i think that may be the problem.
完成的
Then yes, I would take it to the shop where you got the screen changed. Let them know the problem, and the suggested solution. I have ran across this problem many times at my shop.
完成的
thank you i will, i hope i don't have to change the battery .
完成的
No problem. Hopefully you don’t (:
完成的
添加一条评论
Such problem accedentily happen by the following region.Actually that is related to SWI Line problem.
1- Battery must have problem.
2-Battery connector
3- Loose contact of battery to battery connector SWI line.
Battery have 3 pins,one is +ve,-ve & SWI.
On that cases if the problem still same after doing this you have to follow this process but remember need micro-soldering skills.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
lor mo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 44
总计 1,477
