Can I use ethyl alcohol?
can I use ethyl alcohol 70% to clean my device ?
You can, but the high vapor pressure means it will evaporate much quicker than an alcohol more suited to cleaning like isopropyl. Make sure it doesn’t contain any other chemicals that could be left on the device when the alcohol evaporates.
这个答案有帮助吗?
thanks for answering
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 481
5条评论
ethyl alcohol is for drinking. A 70% would be 140 proof. Just what do you have?
由 mayer 完成的
I bought it from the pharmacy It's used for medical purposes And product name is (PURE Nautre's Purity)
由 Amr Ateef 完成的
If its pure, then you should use it. My answer is YES!
由 Kon Dev 完成的
I would strongly recommend using isopropyl rubbing alcohol as, it does not leave as much of a residue as ethyl alcohol can. Electronics are very sensitive.
由 John Potter 完成的
Thank you for helping me. I will use ethyl alcohol in this period then Later I will try to get isopropyl alcohol to avoid any damage
由 Amr Ateef 完成的
