跳转到主内容
A convertible 15" laptop with a touchscreen. Model Number: 80V50010US.
My SSD it overheating!
I have the 15isk lenovo, that is the same model as the one with Nvidia graphics, and my SSD runs anywhere between 52 and 65 degrees C, which I know is very hot for an M.2 Drive, and has been having hardware issues, from failing to install updates, to all the way to total system failures since I got it. I do know that m.2 ssd’s are cheap, but could it be a result of the system just being designed wrong?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
The temperatures you’re seeing is likely the drive over working
How full is your drive? A big problem with SSD’s is they need to move data around so the cells don’t get over worn. So when you have a very full drive the current data often wears a set of cell blocks so these bocks need to be switched out with cell blocks that haven’t changed in a long time. This is called wear leveling in the extreme!
Ideally, you want to leave 1/4 to 1/3 of the SSD empty! Allowing your system to have the free space and not to panic when it needs to move things around.
Here’s a good writeup on the ins and outs: How are SSD garbage collection, wear leveling and TRIM different? and Using Smart Attributes To Estimate Drive Lifetime
I often see people not sizing their storage correctly with SSD’s. I fully understand SSD’s are expensive so people go small! And our love for their speed has us addicted to them. We just need to be smart enough not to run them into the ground prematurely by not giving them the elbow room they desperately need by either getting a bigger drive or cutting back what we store on it.
这个答案有帮助吗?
得分 2
添加一条评论
open it up maybe it is just dirty.
Lenovo Yoga 710-15IKB Fan Replacement - iFixit Repair Guide
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sam Gray (darkling898) 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 379
