跳转到主内容
Lenovo Yoga 710-15IKB Fan Replacement
你所需要的
  1. Lenovo Yoga 710-15IKB Fan  Replacement, Battery: 步骤 1 中的图像 1,1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the ten 3.3 mm T5 screws from the base cover.
    • The screws aren't all the same length. Be sure to keep the screws sorted as you work.
  2. Lenovo Yoga 710-15IKB Fan  Replacement: 步骤 2 中的图像 1,1
    • Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
  3. Lenovo Yoga 710-15IKB Fan  Replacement: 步骤 3 中的图像 1,1
    • Lift and remove the back cover.
  4. Lenovo Yoga 710-15IKB Fan  Replacement: 步骤 4 中的图像 1,1
    • Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
  5. Lenovo Yoga 710-15IKB Fan  Replacement: 步骤 5 中的图像 1,1
    • Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
  6. Lenovo Yoga 710-15IKB Fan  Replacement: 步骤 6 中的图像 1,1
    • Gently lift and remove the battery.
  7. Lenovo Yoga 710-15IKB Fan  Replacement, Fan: 步骤 7 中的图像 1,1
    • Use tweezers to grab the fan harness.
    • Gently pull the harness to disconnect from motherboard.
  8. Lenovo Yoga 710-15IKB Fan  Replacement: 步骤 8 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the four screws holding down the fans.
结论
另外一个人完成了本指南。
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 2,130
