跳转到主内容
Logic board appears to be stuck to case
I am following iFixit repair guide for replacement of upper case for this machine. I am at the point (step 24 and 25) in MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Upper Case Replacement
The logic board is loose but something underneath it is holding the logic board from lifting enough to get at the microphone loose.
But the point that is stuck is right near ports between RJ-45 and USB port. I don’t want to break the board by applying too much force to pry it out. Is there anything else I should be aware of that isn’t in this repair guide?
Thank you;
JK
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The speaker can sometimes get a bit stuck as the foam around it can get sticky holding it in. as you lift give it a bit of tension slowly raising it up the adhesion should break free. Do be careful as the microphone is likely also stuck. If you can use a metal spatula to help lifting the speaker up.
这个答案有帮助吗?
得分 0
1条评论:
It really was stuck but I did get it loose with a pair of needle nose pliers
plying under the corner with the mag safe connector.
完成的
添加一条评论
Agree w/previous , it really was stuck. My first time for motherboard removal on this style laptop so had no insight on where sticking point was until it finally broke free. My advice is to be patient, re-verify all =>11 cables disconnected and screws are out. Continue to gently pry away from sticking side of case.
Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jekillen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 273
