跳转到主内容
加入维修社区 - 创建账户
于 2014 年 10 月 16 日发布,型号为 A1347 和 EMC 2840。
Can I replace HD?
Recently, I purchased a Mac Mini 2014 A1347 model. I understand the RAM is soldered to the board and is not upgradeable. My next thought is to replace the HD and/or add a second HD.
Currently, I am running Mojave on this computer and haven’t had any problems. I was thinking of at least installing a second drive but I am not sure if I need to buy a HD tray or HD cable.
Update (05/20/2019)
If I didn’t want to replace the main HD, can I add a second drive? If so, do I buy an HD tray or HD cable?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
What is your current drive status?
2014年末款 Mac Mini 固态硬盘替换
Mac mini 2014 年末机型的硬盘更换
UPDATE
As you can see from the guides, adding an SSD is a 15 minute job while replacing the hard drive is a two hour job. Go here to select the size of drive to fit your needs:
OWC Aura Pro X2 SSD
Replace or upgrade the PCIe solid-state drive in a variety of Macs.图片
产品
OWC Aura Pro X2 SSD
$239.99
Mac mini Late 2014 固态硬盘图片
指南
难度:
中等
15 minutes
Mac mini Late 2014 硬盘图片
指南
难度:
中等
30 minutes - 2 hours
这个答案有帮助吗?
得分 2
2条评论:
I am not sure what you are asking "current drive status". The computer came with the existing HD. I think it is SATA but I am not sure. The computer is working fine.
完成的
If you have a hard drive model then you can add the blade SSD. If you add the SSD you can make it the boot drive speeding up the boot and running the apps.
Otherwise your only option is replacing the HD with a larger drive if that's what you want.
完成的
添加一条评论
About your question. This unit is very much upgradeable when it comes to adding bigger or better hard drive. Only issue is its not as easy as just popping out a cover and pulling out the drive. To answer your exact question, this model comes with a regular mechanical drive and can be upgraded to a bigger size or even an SSD. You wont need any adapters or cables.
这个答案有帮助吗?
得分 0
2条评论:
I understand what you are saying. However without taking it apart, there appears to a spot below the silver plate to add a second drive. Obviously, I need an HD cable or tray to connect it to the board.
完成的
Adding a second hard drive is not possible. You can only add a blade SSD drive.
完成的
添加一条评论
添加你的答案
jkbmjp 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 23
总计 227
