跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1200 个问题 查看全部
Motherboard screw holder came off causing issues
The iPhone X was working fine until the bottom right screw holder of the motherboard came off. Since then, the ear speaker, main speaker, mic isn’t working and the phone is dead slow. Can I use jump wire to remedy this? I can’t see anything connected through my bare eyes.
Please help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Apple does have a tendency to route traces around screw holes…but not in this particular instance. That said, there are a lot of very fine traces in close proximity to the screw hole so if any one of those is compromised, then you will have issues with your logic board.
Each colour represents a different internal layer of the PCB. You will not be able to see these with your naked eye when looking “from the side”, only when looking at traces from a top perspective. I would take a closer look with a microscope to see if any the adjacent traces are visible, otherwise, you will probably not be able to repair this logic board.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
bijaya.pun 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 140
