跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Screen or logic board
Recently I dropped my I phone and the screen turned black and white and will not respond to touch. So I asked apple support they said I could be a digitizer cable shook loose I checked it out and that wasn’t the problem so I went to the Best Buy to have them look at it and they said that it was either something in the screen or my logic board. I would buy a screen from ifixit but it is 65 dollars and if it turns out to be the logic board I would have wasted 65 bucks is there anyway to tell witch it is?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I would take it to a reputable repair shop to get the screen fixed if you want to avoid the chance of buying a screen and finding out the screen isn't causing the problem.
这个答案有帮助吗?
得分 3
2条评论:
Thank you for your advice but in my area it would still cost more to have the screen replaced than buying it from here
完成的
@nickdabeast421 The answer to your question is no, there's no sure way to tell what the problem is without trying out a known good screen.
完成的
添加一条评论
添加你的答案
Nickolas Borden 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 71
