跳转到主内容
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
2012 MacBook Pro pointer moves without input
Lately my mouse/pointer moves on up and down on the screen clicking files/apps on its own.
When an external mouse is connected the pointer moves very slow. This only happens occasionally. Is my touchpad going bad?
Here is the battery status.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Try to disable the touchpad (option to ignore touchpad when an external mouse is connected). Is it now working fine with your external mouse ?
完成的
添加一条评论
1个答案
最有帮助的答案
Often times I need to replace the trackpad as liquids seep into the touchpad sandwich causing it to mis-track.
So you clearly need a new trackpad MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Trackpad and here’s the guide you’ll need to follow.
But before you go this far given the systems age I would check the battery to see if it too needs replacing. Install this gem of an app CoconutBattery. Take a snapshot of the main window and paste it here for us to see 在已经存在的问题里加入图片. Sometimes the battery swells up pressing on the bottom side of the trackpad which can also damage the trackpad.
Replace a trackpad compatible with the Mid 2009 to Mid 2012 model A1286 MacBook Pro 15 inch Unibody laptop. Part #922-9035, 922-9306, 922-9749.图片
产品
$43.99
这个答案有帮助吗?
得分 2
3条评论:
I posted the battery status from the app. Battery appears to be ok. I already check for swelling too by opening the case. None on the bottom of the batteries are visible.
完成的
Good! Then you only need a new trackpad!
完成的
New trackpad is in route...I'll write back once it is installed!
完成的
添加一条评论
添加你的答案
Ryan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 105
