跳转到主内容
Unit stops charging when powered
I have a macbook air that all of a sudden stopped charging, but still powers up fine with the charger.
The mag safe light does lights up amber, but it does not turn green and the charge indicator on the macbook shows that its charging, but the charge does not increase. This sounds like a logicboard problem, but could it be the battery?
Update (05/17/2019)
Here is a screenshot of the coconut battery tool for the poster who asked me for a exported report of the tool. I was not able to extract the data from the tool itself.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Let take a look at the battery with a better tools. Please download, install and run Coconut Battery and post your results.
https://www.coconut-flavour.com/coconutb...
UPDATE
That battery shows to be poor condition with 1,022 cycles. It will only hold 1/3 of its original capacity. Time to replace it.
Here’s how to change it out:
2014年初 MacBook Air 13" 电池更换
这个答案有帮助吗?
得分 4
1条评论:
I did a Mac Data CSV Export but its just showing the field headers and not the actual data. Do I need to select something first? Please see the image I could only attach my original post.
完成的
添加一条评论
Maybe the power consumption is equal to the power being delivered by the charger? Try emptying the battery, charging with the laptop off, than seeing if the charge has increased.
这个答案有帮助吗?
得分 1
2条评论:
That seemed to do it.. Why is it not charging the battery to full?
完成的
Miscalibrated? Or maybe just a weirdly made battery... I'm not sure.
完成的
添加一条评论
添加你的答案
Scott Larson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 148
