跳转到主内容
The first generation of the saloon style family sedan by swedish manufacturer Volvo.
9 个问题 查看全部
How to fix error code P0302,P0015,P0128,P0304 for this car? Model:S40;
How to fix error code P0302,P0015,P0128,P0304 for this car? Model:S40; Maker:Volvo; Year:2004;
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Here is a link to error codes for Volvo s60
https://www.google.com/amp/s/www.trouble...
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
Here is a link to error codes for your Volvo.
P0118 is MAP sensor error.
这个答案有帮助吗?
得分 0
添加一条评论
Does your car actually have problems ?
P0302 is misfire in cylinder 2 , with a LOT of potential issues ( sparkplugs, injectors…). But if your car doesn’t currently seems to be having engine problems , it is possible that these are older codes for problems that happened once in the past.
for example… could have had some dirty bottom of the tank gas and created one random misfire.
Often one problem links to others and generate other codes.
if your car doesn’t have problems . I would suggest your clear The codes, and run the engine like that. Check your codes frequently, and not the first one showing up. If they happen more or less at the same time And quickly after the engine runs , you likely have an Issue, but come back here and let us know, with more infos and symptoms.
good luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
JohnNickerson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 16
总计 278
