跳转到主内容
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
Screen doesn't turn on after powering up.
I replaced the HDD drive with an SSD drive..reconnected the 4 cables but not the temperature sensor cable for the new drive. After restarting the system I only get the black screen but the computer is running. Anybody can help me what might be wrong??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
What are the logic board diagnostic LEDs telling you? Does an external monitor work with it?
完成的
Not sure how to do that? I am not familiar with apple! Can you tell me how to go about it and where to find it? I also don't have an external monitor.
完成的
添加一条评论
1个答案
最有帮助的答案
First, give the external display a try before you pull things apart.
The onboard diagnostic LED’s are located on the bottom left edge of the logic board
After peeling the tape (which you do need to put back on) read the LED’s from Left to Right 1 ~ 4 Here’s what they mean:
LED #1 - Indicates that the trickle voltage from the power supply has been detected by the main logic board. This LED will remain ON whenever the iMac is connected to a working AC power source. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power source is disconnected or the power supply is faulty.
LED #2 - Indicates that the main logic board has detected proper power from the power supply when the computer is turned on and that logic board voltage regulators are functioning properly. This LED will be ON when the computer is turned on and the power supply is working correctly.
LED #3 - Indicates that the computer and the video card are communicating. This LED will be ON when the computer is communicating properly with the video card. If LEDs 1 and 2 are ON and you heard the startup sound, but LED 3 is OFF, then the video card might be installed incorrectly or need replacement.
LED #4 - Indicates that the computer and the LCD panel are communicating. This LED will be ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the display, then the LCD panel, the LED backlight board, or the cables between might be installed incorrectly or need replacement.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Fabio Pellandini 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 79
