跳转到主内容
An industrial gas-powered stove by Vulcan.
27 个问题 查看全部
Why is my vulcan stove pilots fluctuating when I turn one on?
On my Vulcan stove, the pilots will fluctuate when one is turned on, they will all dim way down or even go out? I have changed the gas regulator, and thermocouple, I need help fast, it is for my restaurant…
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Is the pilot flame blue or yellow?
完成的
It is yellow
完成的
添加一条评论
1个答案
已选择的解决方案
The most common reason why a pilot light would start to burn yellow is that the air intake valve to the pilot light is clogged with dirt. When this happens, air will be blocked to the flame and it will suffer from incomplete combustion (causing the yellow color). If there is a small amount of dirt blocking the air, the yellow color might only be at the tip of the flame. If there is a large amount of dirt, the entire flame will burn yellow.
Another issue with a yellow-burning pilot light is that it allows carbon monoxide to leak into your business’s air. That’s because carbon monoxide is not completely burned up by the lazy flame, and the excess gas will simply escape.
The issue can typically be fixed by cleaning out the air intake valve to the pilot light, which should only be done by a professional who knows how to access and repair the part.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Robert 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 12
总计 269
