跳转到主内容
Apple Watch Series 2, announced September 7th, 2016 and released September 16 2016.
132 个问题 查看全部
The force touch sensor is replaced but it does not work.
While replacing the broken display, the Force Touch sensor was cut off.
So I bought a Force Touch sensor and replaced it.
The Force Touch is not working even though it has been replaced correctly.
Is the product a problem?
Or do I need to do additional methods?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Please ensure that all of the display ribbon cables are properly seated. When I replaced the screen and force touch sensor gasket on the series three I had the same issue. I had to reopen the case and I carefully re-seated all three ribbon cables and then the force touch worked properly.
这个答案有帮助吗?
得分 0
添加一条评论
do you know which one of the ribbons causes this?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Min Gyu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 55
