跳转到主内容
惠普台式机维修指南。
BIOS Not Loading on Start
Hi, I have a Compaq SR5520AN Desktop PC and when I boot it and press F10 (BIOS) it dosen’t load at all.
I have a video:
Any help appreciated
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Hi @dccyt
Can your PC still start windows?
If able to boot, try updating the BIOS to latest.
Try unplugging the hard disk, cd rom does it works?
lastly if not possible, try clearing CMOS by removing the internal cr2032 battery for about 5 mins and put it back in.
完成的
@salmonjapan The PC Does not boot windows, but I can get it to boot a windows install USB. In that, it says that no HDD was detected. I know the port works because I plugged the cd rom into the sata port the hdd was in. The CMOS battery worked, so thanks!
完成的
Hi @dccyt great to hear that you can access the computer.
Most probably if your hard disk is not detected, just change it.
I think SSD price is quite reasonable, so you can consider it for the replacement and also once the system is stable and running well, update the BIOS revision to the latest too.
Cheers
完成的
添加一条评论
1个答案
已选择的解决方案
From your video it IS loading the BIOS. How long do you wait?
这个答案有帮助吗?
得分 1
7条评论:
(By the way, it is solved.)
It would hang on that screen, for however long I left it on.
完成的
I had to take out the cmos and put it back in the pc.
完成的
I agee with Augustine. Looks like your HDD is dead.
完成的
It is not dead surprisingly! It has 6000+ power on hours but is not dead. By the way I managed to get it working.
完成的
SOLVED (I am the writer but I can’t get on to that account)
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Dahcrazychicken 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 657
