跳转到主内容
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
Keyboard not functioning properly.
So I have an old MBP. Aside from a few dings the thing seems to be fine. But there is a issue with the keyboard where you have to press the keys in a certain way for them to work. Not like a short because the keys will work if you hit them in the right way. If you shine a light under the keys look dusty like badly dusty. How should I clean out the keys any tips? Do I have to remove each key or can I teardown the machine and separate the keyboard?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Canned air may help but since dirt seems to be quite a bit and you have already that in mind I would recommend removing logic board and backlight sheet and blow inside out to get the best results. Removing keys one by one might be an alternative solution but less efficient and time consuming.
这个答案有帮助吗?
得分 2
添加一条评论
You could try to spray compressed air under the keys but if the dirt is the result of liquid spill you’ll have to remove the keys and clean under with Qtips and isopropyl alcool. If it doesn’t work you can also replace the keyboard with a brand new one but it’s a good job and many screws to remove and reinstall. Be aware that the 15” Early 2011 has a problematic logic board (820-2915). The graphic chip fails after a few years and there’s no way to repair it. Think of it before investing too much in this machine.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
jadan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 100
