跳转到主内容
加入维修社区 - 创建账户
第 6 代 Apple iPad 的维修指南、拆解与故障排除信息。有无线局域网和蜂窝网络机型可选,容量为 32 GB 或 128 GB。发布于 2018 年 3 月。机型识别号为 A1893 和 A1954。配备 9.7 英寸 Retina 显示屏和 64 位 A10 Fusion 芯片。
Home Button doesn't work after iPad 6 screen replacement
I have been repairing electronics for years. Never had any issues with iPads until recently, home buttons stop working after digitizer replacement. There is no damage to the home button or the cable or anywhere. Anyone else having this problem?
Or have found a solution?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
It could just be an alignment issue, is the metal part of the home button bracket (which is the contact for the button) aligned with the center receiver of the home button?
这个答案有帮助吗?
得分 0
2条评论:
No, it even makes the clicking sound and everything. Even when I install a new button, still doesn't work.
完成的
The clicking sound is not an indicator of anything. Try to align it better with the bracket. I had this issue as well last week.
完成的
添加一条评论
Look at the back of the home button. There should be a tiny black dot in the center of the switch. If all you see is amber that dot has fallen of and the switch will not work when installed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
minnabeezy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 28
总计 1,284
