跳转到主内容
加入维修社区 - 创建账户
Vizio 42" LED TV released in September 2012.
No Video or Audio
Hello, I have a Vizio LCD TV that I found near the trash can at my building. When I try to turn the TV on nothing comes on except for the LED power indicator and then it fades out after a few seconds (which I learned much later that is normal for this tv). But I bought a used power board and then a used video board and nothing changed with the TV.
I am thinking that there is a video board problem. I am considering buying another video board.
Shouldn’t I get something on the screen after replacing the video board? Is the problem definitely within the video board?
This is how the TV looks on the inside.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
djchitown do you at any point get any audio? Have you measure the voltages coming from the power board to the main board? Besides changing the boards, what have you checked?
完成的
I don't hear any audio. I am not sure if the TV plays any audio on power on. I don't know how to use a voltage meter and not sure how much voltage is supposed to come of certain cables.
完成的
添加一条评论
1个答案
I had that problem witrh my Samsung and replaced the main ogic board and it worked. Ithink it could be any one of the 3 boards tho. You will have to check the voltages with your multi meter. Chek out youtube. Tampatec has a good video on checking voltages.
这个答案有帮助吗?
得分 0
1条评论:
I am only away of two large boards inside of the TV. Is there a 3rd?
完成的
添加一条评论
添加你的答案
djchitown 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 20
总计 160
