跳转到主内容
The DKnight MagicBox II is a small portable Bluetooth speaker with Enhanced Bass and build in Microphone for hand free phone calls.
What is the name of this component?
Please check the attached image, I have marked the component. I just need to know what is the name/model of this IC/Component. This burnt out, I can’t recognize its name/model. I want to replace by myself.
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Sure looks like a DIode. You do want to go ahead and try to post a couple of images that are less blurry and are closer to the component.
完成的
添加一条评论
2个答案
The photo is a bit blurry. Is there a map of this system board on its manufacturer’s website?
这个答案有帮助吗?
得分 0
添加一条评论
The component you circled can be either a diode or transistor. It has 3 leads and is the SOT-23 case style. Look at the top and get the code that should be written there. Search for that code like this on google: “SMD CODE xx” where xx is the code you read. That should help to determine the part.
Dan
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jobaer Shuman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 181
