跳转到主内容
加入维修社区 - 创建账户
An SSD, or Solid State Drive, is a type of storage device that uses NAND-based flash memory to store data.
Apple 2016/17 Apple Blade SSD 5GA 34+22 Pins NVMe Converter / adapter
Hi I am looking for a adapter that allows me to plug in a 2016/2017 non touch bar ssd drive to usb or usb-c to read and test drives externally. I cant find anything online
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
3条评论
Did anyone ever find a solution. I’m having the exact same problem. The Apple 22 + 34 pin SSD used in the newer 13” Macbook Pro Fn models.
完成的
Did anyone ever find a solution. I’m also having same problem. Looking for an adapter for for Apple 22 + 34 pin SSD.
完成的
Same problem here. I'm searching thoroughly, but no luck yet. :-(
完成的
添加一条评论
4个答案
最有帮助的答案
@porterk74 - Please review my answer here Access to files on SSD drive.
这个答案有帮助吗?
得分 2
1条评论:
@rmmorshedbk - Sadly, the market for anyone to make a case to hold the SSD is just not there. OWC would have been the only one to have offered one and I don't see anything on their web site.
Apple has moved on to fully soldered SSD drives in the newer models.
完成的
添加一条评论
A little spendy at $60 USD. If it’s for a 128GB SSD then probably not worth it. Could find a comprable (size/performance) for less with greater aesthetics.
https://digitalintelligence.com/store/pr...
这个答案有帮助吗?
得分 1
1条评论:
How does this Tableau adapter connects to PC/Mac? Is it SATA, or USB?
完成的
添加一条评论
There are some adapters for this apple SSD (22+34 pins) but they are either very expensive or "out of stock". And that is because they don't manufacture them all the time.
I will give you the information, however....my suggestion to everyone of you is to try in contacting the company or the manufacturer behind these products, and see if they could build you one adapter especially for you. YES >>You may say that I am kidding....but....I am not. It may really come to the point where you will have to deal with this situation by yourself and you may be alone....between you (the merchant) and the company (manufacturer).
Also...keep in mind that you could also get a refurbished MacBook Pro, and if that is the case, you could use it as a tool in order to recover your data with it.
So..the only solutions remaining in 2026 are down to 3:
And that is all. I hope this will be help somebody, if not...anybody.
"Well, the golden lamb we've sent makes us feel better now .... but you know it's just a drop in the sea of tears" (Klaus Meine / White Dove - 1994)
这个答案有帮助吗?
得分 1
1条评论:
If you could reach out to me I can ship you one of my readers, and you can just ship it back to me at your convenience, I don't do a lot of MacBook recoveries that aren't from soldered storage these days, and I have a few of them. I have a custom-made PCB and adapter that I designed several years ago and had PCB Way build several of them, specifically to recover data from 38+22-MacBook Pro SSDs. They're 38+22-pin to USB 3.2 Gen2x2, so quite fast, they get the job done. Since it uses the NVMe protocol, and I was sick of soldering pins to a USB controller or M.2 carrier board for clients, I figured I'd just do the 2230/2242 to MacBook adapter in reverse. PCB Way does kinda kick a$$ for small volume. I'll ship one to you if u still need it. Or you can send me your drive and I can recover your data, but that cost $. If it's just a case of mounting the drive to get data, I can send you one of my readers (just pay the shipping back and we're square).
- Jackson
PhixesPhones@gmail.com
完成的
添加一条评论
- Jackson
这个答案有帮助吗?
得分 1
1条评论:
Your reader is for a 22+34 pin? I am looking to recover the data from my old 2017 MacBook Pro SSD and can't find any solution.
完成的
添加一条评论
添加你的答案
kirk 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 66
总计 6,343
