跳转到主内容
An SSD, or Solid State Drive, is a type of storage device that uses NAND-based flash memory to store data.
52 个问题 查看全部
Apple 2016/17 Apple Blade SSD 5GA 34+22 Pins NVMe Converter / adapter
Hi I am looking for a adapter that allows me to plug in a 2016/2017 non touch bar ssd drive to usb or usb-c to read and test drives externally. I cant find anything online
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
3条评论
Did anyone ever find a solution. I’m having the exact same problem. The Apple 22 + 34 pin SSD used in the newer 13” Macbook Pro Fn models.
完成的
Did anyone ever find a solution. I’m also having same problem. Looking for an adapter for for Apple 22 + 34 pin SSD.
完成的
Same problem here. I'm searching thoroughly, but no luck yet. :-(
完成的
添加一条评论
2个答案
最有帮助的答案
@porterk74 - Please review my answer here Access to files on SSD drive.
这个答案有帮助吗?
得分 2
1条评论:
@rmmorshedbk - Sadly, the market for anyone to make a case to hold the SSD is just not there. OWC would have been the only one to have offered one and I don't see anything on their web site.
Apple has moved on to fully soldered SSD drives in the newer models.
完成的
添加一条评论
A little spendy at $60 USD. If it’s for a 128GB SSD then probably not worth it. Could find a comprable (size/performance) for less with greater aesthetics.
https://digitalintelligence.com/store/pr...
这个答案有帮助吗?
得分 1
1条评论:
How does this Tableau adapter connects to PC/Mac? Is it SATA, or USB?
完成的
添加一条评论
添加你的答案
kirk 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 18
过去 30 天: 55
总计 4,939
