跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1199 个问题 查看全部
iPhone X battery connector replacement
Alright, so I posted on here a while ago about salvaging an iPhone X that was water damaged, and I did my best to clean it, but after taking a better look at the board under magnification I discovered the battery connector on the logic board seems to be either corroded or fried.
I have found out that the connector can be replaced, but will require micro-soldering. At this point it’s more or less practice, because he’s gonna just buy a new phone if I cant fix it, but it would be awesome to get it working again.
I was wondering if anyone here has any input on the difficulty/requirements of this job, because I can’t seem to find anything about it online. I guess my main questions are: will I need to open up the “sandwich” of the board to replace this connector, and what type of solder should be used for this job? Also if there’s anything else I should look out for or be careful about to do this job successfully.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Replacing the logic board will be at least double what Ian suggests as a repair price so a repair is the best route forward. Personally, I think a connector repair would cost even less than $150 but don't go for too cheap a repair as there is a lot of risk involved when working on an iPhone X board and you want to be dealing with an experienced tech who values quality work.
As for doing it yourself, don't underestimate how difficult an FCP repair is. There are three main issues:
  1. Component Density: iPhone logic boards have an insane level of component density. Inadvertently moving your micro-soldering iron, with a tip of 0.15mm, even just a bit will clear out a bunch of components like a windshield wiper. When using hot air, the smallest nozzle can directly blow on dozens of components, many of them 01005 packages, at the same time, blowing them off the board and never to be found again. Some of these components cannot be sourced (unless you want to buy 10 000 of them and wait 6 weeks).
  2. Thinness of the logic board: The logic board on the X is very thin and that means that any heat you apply will be quickly felt throughout the board. That means that while you fiddle with the FPC, the CPU, NAND and other critical chips, many of them underfilled, are heating up, the solder balls are expanding and eventually, they can bridge or blow out.
  3. FPC Connectors themselves: It is essentially a flimsy bit of plastic and that means they are easily damaged during the repair. Never buy just one replacement FPC…you will often go through more than one to get it just right. If the hot air doesn’t distort it beyond recognition or outright just melt it, then touching up the connections with a fine tip soldering iron will usually mangle them up.
This is a bit tongue in cheek and I’m certain that any experienced micro-soldering tech is smiling as they read this…but only because we have all been through this. Youtube videos make micro-soldering look easy but believe me, those that make videos have tons of experience and really master their field.
So by all means, practice, learn a new skill and save a great device. But please, don’t practice for the first time on an iPhone X. When you can successfully remove and re-install the same FPC connector and insure that it has electrical continuity…keep practicing. Only then would I suggest you try the iPhone X.
P.S. In all fairness, the battery connector on the X is probably one of the easier ones to replace as it has a lot of “metal” in relation to plastic. The hardest ones are digitizer connectors because they are long, have ~50 pins and warp as soon as you apply heat.
这个答案有帮助吗?
得分 2
添加一条评论
Unless you know how to solder and know exactly what’s wrong with it, I would take it to a local repair lab where they do micro-soldering. It would probably be ranging from $150-$200 but the outcome is that with your friends permission you can resell it and make a good profit! or use it for an extra phone!
这个答案有帮助吗?
得分 0
1条评论:
I've done plenty of soldering in my day, just not microsoldering. It would be cheaper for him to just replace the logic board for that price, and he doesn't use face ID anyways -- as far as I know that's the only downfall of replacing the logic board right? He said he doesn't care about the data on there.
As I said in my original post though, this is more or less practice for microsoldering. I have no use for the phone and I guess I could resell it, but it would nice to be able to fix it. I have some old phones lying around that I could do a few trial runs on first, but I just want to be prepared.
完成的
添加一条评论
添加你的答案
Elliot Tregoning 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 33
总计 2,162
