Touchscreen doesn't work after bent frame
So my iPhone X got stuck in the door and the frame bent. Everything still works except for the touchscreen.
I installed a brand new screen and the touchscreen still doesn't work. What is going on here?
Mostly this problem appears after forcely dropped because iphone x board have two logic board that are connected
throw low temp solder.So that might be causes some pin are not connected.Even though might be many causes.
1-touch connector pin open.
2-bad connection between two layers of mother board.
3- touch connector side broken.
So these are all for prediction.So,you have to clear understand that by seeing .
这个答案有帮助吗?
Thank you Akash. I understand number 1. What do you mean with number 2? Bad connection between 2 seperate logic board or bad connection between layers of single logic board? And what is the "Touch connector side"?
The iPhone x is a phone with 2 board joined together by lots of tiny little solder balls... if the phone is bent or dropped its possible for the 2 boards to split apart or loose connection to each other
Absoulately yes.
Mine dropped real hard now the touch is no longer responsive.
Even after using a known good display.
Pls advise
Philip
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 623
