跳转到主内容
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
问题已关闭
Is it possible to install a SSD
Hey guys of ifixit,
Is it possible to install SSD to my iMac 5,1 20" (Late 2006)?
Thank you for your help.
Regards
Jan
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
已选择的解决方案
I like the 3.5" OCZ Vertex drives for desktops. The 2 series will work just fine for you. Just do a web search for "OCZ Vertex", you'll find them all over.
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
SSD's are normally 2.5 inch drives. your iMac has a 3.5 inch drive. you will need an SSD that has an adapter plate or purchase a seperate adapter plate. Many SSD's come with one included.
这个答案有帮助吗?
得分 2
5条评论:
Ah okay so it is generallay possible and I need an SSD who supports SATA not SATA II.
Thank you.
完成的
was that negative towards me or for the comment from the OP on my post?
pretty much any SSD will work and it's best to have the adapter plate to be able to mount it securely is what I said.
完成的
Does it matter if it's a sata-1/2/3 ssd for this type of mac?
完成的
Yes it should be a SATA III
完成的
This systems SATA I/O speed is only 1.5Gb/s. Best to stick with a SATA I/II 1.5/3.0 Gb/s SSD. SATA III is a waste of money and could be a problem if it's not auto sensing.
完成的
添加一条评论
You could also swap-out your optical drive to hold your HD and use the SATA port for your SSD.
Review this Answer if you think you might like to have your cake and eat it too ;-}
这个答案有帮助吗?
得分 1
添加一条评论
OCZ SSD Agility 3 Series - 120 GB
would also work?
这个答案有帮助吗?
得分 0
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 3,753
