跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
My iPhone 7 front glass has cracked.
Hi! My iPhone 7 front glass has cracked. But, my LCD panel is still in good condition.
  1. If i order “iPhone 7 Screen with fix kit”, is it everything I need to repair my phone?
  2. iPhone 7 Screen being sold by iFixit, includes front glass, lcd display, front camera assembly, speaker and lcd shield plate. But I only need front glass. Is it availiable to buy only front glass?
  3. This is the first time, visit ifixit.com. Sorry :( Which one is the cheapiest way? DIY with iFixit.com? Or visiting Apple Service?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
So in short term the actual screen that displays the picture and the glass are glued together, unless you have an expensive machine or amazing patience and the skill of not breaking the screen (which is very easy to break) you will need to buy a new screen. If you think the iFixit kit is expensive there are plenty of cheaper ones on eBay, but you might not get the same quality, if you do get that route either make sure it comes with the tools needed or you buy them separately. A YouTube tutorial or the iFixit one should help you out. Hope you get it fixed :)
这个答案有帮助吗?
得分 0
1条评论:
Thank you so much for the kindly reply.
完成的
添加一条评论
最有帮助的答案
1: iPhone 7 Screen Looks enough, however please reuse as much parts taken from the original phone as possible, some parts are programmed individually.
2: Don’t do it as DIY.
3: Ifixit plus shipping can be quite expensive in some areas, in that case just go to Apple.
iPhone 7 Screen图片
产品
iPhone 7 Screen
$69.99
这个答案有帮助吗?
得分 1
1条评论:
Thank you so much for the kindly reply. iPhone 7 Screen with Kit plus shipping fee is quiet a lot :( I think I better visit Apple Service. Thank you.
完成的
添加一条评论
添加你的答案
이DC 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 221
