跳转到主内容
My PowerBook G4 does not recognize it own hard drive why?
My PowerBook G4 does not recognize internal hard drive. when i boot without cd it will not boot and i will see a question mark on the screen and a small icon that represent mac os. i have Mac OS X 10.3 that i used on my old iMac. when i restart the computer and press ALT it will bring a screen only with cdrom and it will read the cd, when i press enter to install it will reboot and bring a white screen with a Traffic sign that says (do not enter)and ends there. i removed the hard drive and connect to a pc and formatted it but still it will not recognize the Hard drive. what can i do to get to clear that sing and get to installation window? is the problem the Mac OS and if yes which version do i need? pls help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
6个答案
已选择的解决方案
Tiger (10.4) would be the best Mac OS for your machine. If the machine is full ram and has a fast drive you can also install Leopard (10.5) but the machine performance could be a little sluggish. Now your problem is the installation disk. You'll have to find a retail installation disk (black disk) cause your iMac disk (grey disk) won't work with the PowerBook. This is a specific installation disk for the iMac only. Also, the hard drive must be formated with a mac, not with a PC.
这个答案有帮助吗?
得分 3
3条评论:
Well stated +
完成的
I listed where to get it in your other question
完成的
I thought this sounded familiar.
完成的
添加一条评论
Hi
I just replaced my old hard drive with a new 80 Gb drive (PowerBook G4 1.5 GHz). I tried to boot up with an OS 10.4 for which I have a CD.
Everything goes well until it asks to identify the hard disk to install the software. There is no hard disk visible.
On the other hand if I open Disk Utility, it shows the hard disk.
What am I doing wrong?
Much appreciate your advice.
这个答案有帮助吗?
得分 0
添加一条评论
Hi
I am trying to install Tiger 10.4. So my software version is OK.
If the hard disk has to be formatted before the software can be installed maybe that is what is missing in my hard drive.
Are the instructions on how to format my replacement hard drive?
Many thanks
这个答案有帮助吗?
得分 0
添加一条评论
Please when you on it this is what you see on the screen “ you need to restart your computer.hold down the power button for several seconds or press the restart button
这个答案有帮助吗?
得分 0
添加一条评论
Something that just bit me was that the PowerPC computers require a “Apple Partition Map” formatted drive to boot from rather than GUID which is needed to boot Intel based machines. I used SuperDuper! to clone the drive, but when I swapped it out it would not boot because I had used the wrong partition scheme. So I needed to reformat it with “Apple Partition Map” and then re-clone it.
这个答案有帮助吗?
得分 0
添加一条评论
just format the whole drive as FAT32, Master Boot Record externally, MAC OS will recognize and then format it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Julius Nfor 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 27
总计 3,084
