跳转到主内容
型号 A1059 或 A1099 / 20, 40, 或 60 GB 硬盘 / 触控转盘
Zif HDD connector type
Hi All!
The HDD Zif connector in my iPod has cracked and failed. Does anybody know what type of connector it is? It looks to have 40 pins but I don’t know what its called or who makes it so I am struggling to order a replacement. I have removed the old connector and all of the pins are good under it.
EDIT:
Below is an image of the iPod’s LCD connector. This is identical to the HDD connector which is missing from my board:
Thanks,
Oliver
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Here’s the part:
Apple part # 632-0259-A
https://www.powerbookmedic.com/iPod-4th-...
iPod 4G Hard Drive Cable
Here’s how to install it:
iPod 4代/Photo 硬盘更换指南
Attaches hard drive to logic board图片
产品
$9.99
这个答案有帮助吗?
得分 2
2条评论:
Hi mayer,
Thank you for your reply!
I should have made my question a little clearer, it’s not actually the HDD ribbon that has failed, but the Zif connector on the iPods logic board.
do you know where I might be able to get a replacement from?
I’d rather not replace the logic board as it’s a U2 special edition that I have.
Thank you,
Oliver.
完成的
Oliver
from what i have been looking at its a zif connector and if this is broken a new ziff connector will need to be re-soldered onto the logic board...
same boat myself. I know this is some time after but i always still would like to know the anwser.
Dane
完成的
添加一条评论
添加你的答案
Oliver 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 31
总计 1,200
