跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2265 个问题 查看全部
Screen response is inconsistent after replacing broken screen
I replaced the broken screen ip7
However it took a long time to turn on. In between the phone turned off and restarted.
After it turned on the touch function is inconsistent. Hence changed screens couple of times but no success.
Can anyone please advice?
CC
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
When you replaced the screen did you disconnect the battery? You mentioned you replaced the screens a couple of times? All from the same supplier? The iPhone 7 can be really picky about how it behaves based on a LOT of variances in quality, IC chips used and connectors. Where did you get the screens from?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
CD Fix 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 31
