跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
Is it ok to replace the screen
I dropped my phone and now it has a slight bend. Should I get it fixed?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Why not sure you can fix it .There is small bend no problem.
完成的
添加一条评论
1个答案
已选择的解决方案
Since the iPhone logic board inside is firmed to the housing with screws, there might be consistent pressure on it that could lead to troubles sooner or later. Screen too may be working bad and create issues. It would be a good idea before replacing screen to straighten the housing or replace that part too after removing the logic board.
Here’s the guide to help you do the job:
iPhone SE的逻辑板更换
这个答案有帮助吗?
得分 4
3条评论:
The bend is only on the volume rocker side And the replacement is Coming in a week. Is it ok to wait or should I fix it as soon a possible?
完成的
@shaven_gren It shouldn't be a problem, the left half of the housing is mainly occupied by the battery and smaller components. Unless you feel unusual constant heating coming from the phone it won't be a problem to use it as it is for some time.
完成的
Alright thanks
完成的
添加一条评论
添加你的答案
rossianthony004 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 108
