跳转到主内容
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
408 个问题 查看全部
My iPad charging situation is very hard!
I have this iPad 4 since almost 2015. It has face a lot of problems with charging and a new one is here!!
Sometimes it shows that the “accessory may not be supported “ or it does not charge unless I put it on a certain angle. I changed the cable and the charger, I cleaned the charging port and nothing happened !
after buying a new usb cable it started charging
but again, it started to show the “not charging” thing again but in fact it charges despite the fact that it’s showing that it's not charging
but the charging is EXTREMELY SLOW, the voltage and the energy of the charger and the cable are just perfect to the ipad needs but it barely charges 1% in an hour !!!
I’m really confused and I need advice please???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If the cable and the charger are both brand new, then the problem may be your battery. As a battery ages, it loses its ability to charge and maintain it’s charge. If your battery is 4 years old (you’ve had it since 2015), then it’s probably losing it’s ability to function efficiently.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Siham Daher 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 61
