跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Why is there no action from taptic engine after audio ic replacement?
So i recieved an iphone 7 that had the audio ic replaced. The customer said that it doesnt vibrate and people can not hear them as well as putting it on speaker changes nothing and sound still comes through the top speaker. I tested everything and they are correct about all of the issues. Also they stated that it will restart randomly for no reason. If any one could help me narrow down what's wrong with this board I would greatly appreciate it. Thank you all in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The first thing to suspect is that the Audio IC repair didn’t go smoothly. If the “new” symptoms roughly correspond to the Audio IC repair, then I would inspect the workmanship and use that as a clue.
Assuming the Audio IC was properly replaced (with jumper on C12 at least) and there no obvious signs of missing, dislodged or bridged components, then I would start probing the the ARC circuit (taptic engine) and work my way from there.
这个答案有帮助吗?
得分 2
1条评论:
in my experience, if this occurs - reballing homer would help.
完成的
添加一条评论
添加你的答案
Blaked89 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 520
