跳转到主内容
Repair and support information for HP Laptops, designed for home and home office use.
1040 个问题 查看全部
My Laptop Suddenly Died
I have a HP pavilion x360 14-ba163tx that I bought last year. I had no problems using it and I'm happy with my laptop.
Until last week.
On Wednesday, I turned on my laptop, charged it and used it to check a windows 10 update. After that, I put it on hibernate and put it back in my bag.
2 days later, I tried to turn it on but the boot logo won't show up. The LED power indicator turns on but then it turns back off. I plug in it's charger thinking it ran out of power. The charging LED also turns on. I tried turning it back on again but the screen still stays black. Then I noticed the fan and HDD running and the power indicator turns on for a little bit before they suddenly stop and start again by themselves over and over again until I manually turn my laptop off by holding the power button.
The next day, I brought it back to the store that I bought it from and they said it was the motherboard. I was very confused, because it worked fine on Wednesday and I didn't even turn it on until Friday night. They said the HDD, RAM and SSD still works.
I also don't really use my laptop that often nor do I use it for heavy programs. Only some like, Skyrim, Sims 3 & 4, Adobe Lightroom, Office and surfing the web. I also undervolted it so that it will run cooler while being stable because back then the laptop would get hot even when using it for surfing the internet.
My warranty ended last month and they said replacing it is basically buying a new laptop. I want to know what happened to my motherboard that suddenly died after one year. I had an acer laptop 3 years ago and it's still running smooth. I'm confused as to why my HP laptop died only after 1 year.
Any idea what happened and what I should do? I sent an email to HP but they haven't replied yet.
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
A similar thing happened to me, with my HP 250 laptop. It suddenly and unexpectedly died on me after just one year. And right after the warranty expired. It was working fine just before that. I suspect that HP systems have a deliberate kill switch in the motherboard forcing you to buy another one.
完成的
Yeah I'm sick to death of this problem!! My hp laptop is just over a year old, only ever used by me for writing (I live alone) ... and yet it keeps randomly switching itself off while I'm working. It goes DEAD - even the light doesn't come on when plugged in. It then stays dead for a day or two, and if I leave it alone completely, at the very least overnight, I can then switch it on next day (or after a day or two) and hope for the best. How am I supposed to keep my job this way? And because the warranty is only for one year, they're not going to do anything about it. Why should we pay for Unreliable??
完成的
Yep, I have a 360 15 that’s doing the same thing, after only 1.5 years of working. I’ve been informed by a friend that I got lucky with my two previous HP laptops, as both of them lasted about 7 years each, and doing an online search with this issue I understand why. I’ll never buy another HP.
完成的
@Krista Solars
What is the full model number of the laptop as shown on the product info label on the bottom of the laptop?
What have you tried to do to fix it?
Don't give up so easily as there's a few things that you can try to see if you can get it going again
完成的
添加一条评论
2个答案
已选择的解决方案
Yeah, I’m not surprised the motherboard may be bad - it’s a common HP Consumer failure. To make matters worse, you have an HP that needs a complete teardown to work on. The issue with their motherboards is they have a tendency to fail in 1-3 years, especially in laptops. It doesn’t happen in every single HP laptop, but it happens on a disproportional amount of them. I’m not a fan of their consumer hardware because of how failure prone it is (and how difficult some of it is to work on), but it works for you and you’re happy with it. I wouldn’t fix it if the motherboard diagnosis is confirmed, but if it’s something like the memory it’s usually a cheap enough fix. The service manual can be found here.
I would verify their diagnosis, just to be sure. Take out the hard drive(s) out of the system and run it without that and see what happens. If it doesn’t work, try using completely different RAM - some of the HP systems I’ve had even have trouble with their OEM supplied memory. If it works with different RAM, the OEM RAM has failed in a way it’s rejected by the notebook (despite being the memory HP chose) and you’re dealing with a picky HP motherboard. While it may not work in an HP ever again, it may work in another system if it’s something that doesn’t show up in a extended (8 hour) memory test. Hold onto the module with the expectation the issue will reproduce in another system until visually proven good to avoid a major headache. It may also be a case of a single module failure taking it down due to a mismatched pair the notebook does not like and it no longer boots. Replace both modules to be 110% sure there will be no boot issues due to a module incompatibility or a hidden issue on the “good” module.
However, if you do find the RAM does not fix it, remove the wireless card for good measure. These don’t fail very often, but when they do they fail in ways that are frustrating to diagnose short of removing it entirely (and in some cases, stripping the system for diagnostic purposes). If this is bad, you NEED the service manual as HP has a WLAN WL in their Consumer BIOSes.
这个答案有帮助吗?
得分 2
2条评论:
Thanks for the reply!
When the store checked my laptop they also tried to replace the RAM, but it still didn't work. I already extracted the HDD and SSD from it and tried to run it but still won't work. I'm going to take it to another service center tomorrow to see if they can diagnose it further. My model is hp pavilion x360 14-ba163tx btw.
Didn't know that HP laptops are like that since this is my first time owning one and they seem decent :/.
Thanks again!
完成的
I've known this since the 2007 DV series with the GPU problems. Their consumer machines are the worst offenders when you're talking about consumer grade. If it has a dedicated GPU, they're even more failure prone. The giveaway is if it has dual large cooling plates on the heatsink if you aren't sure about the specs, along with a second chip support besides the one for the CPU. To top the potential for a GPU failure (some boards offer the 940MX), yours also has the chassis you need to gut for service :(.
The business lines that aren't glorified consumer models (EliteBook and HP Z) are good, but you pay a premium for those. The Haswell generation eliminates the WL from the business like entirely on the EliteBook and Z lines (it's gone since HP Z designs most of the Elite line now) as well :-). Not sure about the ProBook, but those are more or less glorified Pavilions in a way. It may or may not be left behind.
完成的
添加一条评论
Same Thing l found issue l can bring back to life easy l worked hp for very long time My model is Hp elitebook 840 g7 on monday died l try use usb bypass generial and it came back life but hour later shut by it own l try install bios and all fixed it wont happen again it was pretty easy
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Yuh Ion 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 51
总计 7,474
