跳转到主内容
Model Number: M305D-S4829. Processor: AMD Turion™ X2 Dual-Core. Installed Memory: 4GB (PC6400 DDR2 800MHz SDRAM). Hard Drive: 250GB HDD. Display Size: 14.1" widescreen.
5 个问题 查看全部
问题已关闭
Screen no longer works
Works fine if I hook it to a monitor but the screen no longer turns on
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Thanks. Turns out when I split the case I did find a loose cable. Now it works great!
完成的
添加一条评论
3个答案
已选择的解决方案
If it works when hooked to an external monitor then you either have a bad cable, cable connection to the LCD or a bad LCD. I would open it up and check the cable to make sure its connected and has no breaks. If the cable checks out you probably need a LCD. Good luck.
Toshiba Satellite M305D-S4829 Motherboard Replacement
这个答案有帮助吗?
得分 2
1条评论:
+ move the screen up and down and see if it flickers - thus indicating the data cable
完成的
添加一条评论
This happens to my satellite too. Heres what I do to fix it.
1.Take Battery out
2.plug power in
3.while battery is still un-plugged and turned on pick up your laptop and tip it all the way sideways quickly. You should hear your fans boost and your screen will turn on.
4. replace battery while still turned on.
这个答案有帮助吗?
得分 0
1条评论:
If this is working, aren't you essentially resetting the CMOS? If so then a new CMOS battery would solve this issue.
完成的
添加一条评论
been using my toshiba satellite M305D without battery and directly AC plugged in. the last use was it was turned off but forgot to unplug from the ac. now the monitor is black. pls help. the turn on button lights up but no monitor, still black..
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 3,545
