跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Water damage iPhone 3GS
The other day I had the bright idea to go to the pool with my iphone in my bathing suits pocket. I wanted to listen to music but I found a way to forget my headphones. Anyways, so yeah I have my iphone in my pocket and once at the pool decided to jump in the water so I would find the water less cold. Thats when I realised what i just did and told myself: "please don't tell me you just did that". So yeah i don't even want to look at the phone thinking after once dropping it from a 2nd floor face on the ground (no damage) and once dropping it in the water with no damage, this time that was it. So I stay a bit at the pool feeling stupid and letting my phone dry to the sun. After 15 minutes, I decided to go back home and search "bring my iphone back from the dead". I find the rice trick do that for 3 days. Then open my phone put alcohol to kill any corrosion and stuff. Plug my iphone and too good to be true It opens no problem, i unplug it no battery problem, i start texting my friends its working and then when i want to go back realise... no more home button. First reaction ill open it again to see If i missed a spot and try turning it off... no more power button. So yeah i have my iphone back perfectly working, no lcd or battery problem and no data loss, but for my power button and home button... Has this happened to any of you? What should i do? I don't want to order a bunch of buttons to realise its not the button or whatever. Is there a way to diagnose where the problem is from? logicboard? button itself? Looking at the logicboard there doesnt seem to be corrosion or anything.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
sounds like you did a good start on the first aid. I'd let the phone"die" or run out of charge, then open it up and use the alcohol to clean the top of the dock connector (it makes contact with the home button) and then I'd clean all of the connectors on the motherboard and all the flex ends. allow it to dry and repeat the process. when it's dry again i'd reassemble and see what results you get. If still no home button, take a look at the gold prongs on the back of the home button and check you haven't flattened them taking the display off..lift them up a little. if still no joy on the power button is part of the headphone jack/volume/mute flex.. the guide is on the right. I'd look for a part that has the metal connectors already attached, not just the flex on it's own-it'll make life easier and there is usually not a lot of difference in price. the home button could be the dock connector or the home button flex.. more likely the dock.
这个答案有帮助吗?
得分 3
2条评论:
Thank you so much!! I just did what you told me and combined it with your water damage 3g iphone guide and now my Iphone is fully working!!
完成的
brilliant! glad to have helped and thanks for accepting the answer..it should help others in similar situations.
完成的
添加一条评论
添加你的答案
Jean Sebastien 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 7
总计 2,169
