跳转到主内容
2016年版Retina MacBook的更新版本。型号A1534,EMC 3099。现在采用更快的Kaby Lake处理器,最高可达1.4 GHz Core i7,支持Turbo Boost加速至3.6 GHz,SSD速度提升高达50%,并支持高达两倍的内存。
How to install a system on an erased drive
My customer booted from an external drive and used Disk Utility to erase the drive. So the repair/restore partition is gone.
It boots and runs fine from an external drive but when I try to install a system it tells me it has to be connected to a power source but there is only the one USB c port.
Any ideas on how to get a system on it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
This is one of the big issues with the MacBook’s.
You’ll either need to get a USB-C hub so you gain access to a second USB-C port so both the power and your OS installer can be connected together. or use the WiFi connection to the Internet to do an internet recovery.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
mayer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 12
总计 469
