跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1200 个问题 查看全部
Why is my iPhone X inverting colors after screen replacement?
I recently got my phone screen replaced after dropping it, and within the same day, it randomly inverted the colors. It now inverts the colors back and forth every twenty minutes or so. The 3d touch is also unresponsive at times. What could cause the problem? Should I ask the person who replaced the screen to fix it/replace it again?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
HI! How did you solve this issue? I have the same problem.
完成的
添加一条评论
2个答案
已选择的解决方案
I would certainly go back to the repair shop and have them take a look. It is probably a defective replacement screen and this should be covered under warranty.
这个答案有帮助吗?
得分 3
添加一条评论
No dough that is the cause of defective screen.The iPhone x and X-max series have a lot of issues and also sensetive.
After screen replacement the unbalance fitting creates that problem or If in the case of copy LCD that the risk is highly.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Marti Steverson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 3,908
