跳转到主内容
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
310 个问题 查看全部
No power, diagnostic results, power supply, logic board, or DC cable?
I’ve looked through the entire forum, but haven’t found anyone who posted their diagnostic results with any answers. I’m running in circles at this point.
I’m trying to determine if it is the logic board, power supply, or DC power cable from PSU to Logic. System does not power on at all.
State 1:
LED #1 comes on - which means standby power is present.
Pin 1 & 4 - has 12v
Pin 1 & 11 - has 12v
Pin 1 & 12 - has 0v
If I hold the power button on for 3 seconds:
State 2:
LED #2 however, never comes up or blinks during this whole process.
Pin 1 & 4 - has 12v
Pin 1 & 11 - Volt will just down to 3v then 1v and slowly decrease and rest at 0v
Pin 1 & 12 - Will have 4.59v
If I press the power button once it will immediately go back to “State 1”
All this started happening immediately after I installed an update for Sierra, the system would randomly turn off, it happened about 3 times and then it will turn back on by itself after a minute or 2. But after it happened for the third time, it no longer turned back on. I’ve done all the disconnect power cable, reset SMC, tried another outlet, etc. I’ve also pulled out all the RAM.
**4/16/19** Update
Swapped power supply with another working iMac same exact model. The other iMac worked which means the original power supply works. The iMac with problem still does not turn on with another power supply. Reacts the same way as mentioned above.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Heating? Can you please explain you mean by heating?
完成的
At this point I think you've proven the issue is within the logic board.
There are additional power regulators on the logic board I'm suspecting you damaged them.
This is a common issue when the system gets a power line hit. Really need a good surge suppressor or better yet a UPS! The other risk is the peripheral devices also need protection as a lighting hit could enter through the other ports as well (USB, FireWire, DisplayPort or Ethernet)
完成的
添加一条评论
1个答案
已选择的解决方案
Replace the power supply first:
iMac Intel 21.5" EMC 2308 Power Supply Replacement
UPDATE 4/18/19
Did other things (electrical) in the house get hit?
这个答案有帮助吗?
得分 3
6条评论:
Ok, I'll try this first. Part comes in on Friday. I will update status as soon as I get it installed.
完成的
完成的
What are the diagnostic LEDs telling you?
完成的
Same exact situation as above. No change on LED 2, even though voltage is changing at pins 1 and 11.
完成的
Put your power supply in the other machine to see if it works, your conclusion that it works just because another power supply does not is in error.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Win 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 109
