跳转到主内容
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
unable to remove bottom case
Having removed the 10 screws of the bottom case, I have lifted an lifted the case and unable to "pop" it off. How hard does one have to lift? I'm afraid of "dimpling" the case.
This MacBook Pro has the built-in battery. Could there be glue holding the bottom case a la iPod Batteries glued fast? Or, is there a tool to reach into the area where the bottom case seems "glued" to something?
Thanks,
Vladimir Vooss
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I've done that, usually when I missed a screw.
完成的
添加一条评论
2个答案
已选择的解决方案
There's a few simple clips on the the lower case that lock into plastic retainers attached to the upper case. They are similar to the clips found on the new MacBook Unibody 13" lower case which can be seen here. One of the black plastic clips mounted to the upper case of a Mid-09 15" MBP Unibody is visible in this picture.I usually wedge my fingers under the lower case near the vent and pry up to pop the lower case off.
这个答案有帮助吗?
得分 3
1条评论:
Very good +
完成的
添加一条评论
This model has no glue holding the bottom panel if it's sticking at the back end where the display hing is just wiggle and lift gently should come off easily
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vladimir Vooss 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 3,018
