跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
Power button is not working - how to fix it?
Hi,
in iPhone 3GS, the power button is not response.
You press it but no action. The phone felt down to the floor many times.. My question is: What could be the way to fix it? what attached to this button? I know that there is a flex reibbon (Gold cable) that attached to the power button, earphones, volume buttons and it is not easy to fix. That's the only part that affected not working power button? That ribbon?
tnx
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Yes, that ribbon. The Headphone Jack Ribbon Cable #5. A short term fix that sometimes works, is to squeeze in that corner the front screen and back case together (pinching) while pushing the button. When you repair the 3GS, make sure it is OFF before and during all repairs.
这个答案有帮助吗?
得分 1
3条评论:
How can I know what is #5 cable? Where are the numbers of these cables? Is there a table of it? thanks
完成的
And could you please add a link of picture of that part?
完成的
pintching did not work. So what could be the problem? and what is the solution?:) The vibrate button,headset hole, and the volume button are working.
完成的
添加一条评论
i phone off but on no respons age on celo now on way
这个答案有帮助吗?
得分 0
2条评论:
not quite sure what is going on with your phone. Give us more information.
完成的
iphone 3gs no on now but age on celo others on way
完成的
添加一条评论
添加你的答案
Shai 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 28,911
