跳转到主内容
第六代 iPad 发布于2018年3月。拥有无线局域网和无线局域网+蜂窝网络机型,32GB 和 128GB 两种储存容量可供选择。配备了 9.7 寸的 Retina 视网膜显示屏和 64 位架构的 A10 Fusion 芯片。
194 个问题 查看全部
New iPad 6th gen won’t turn on after hard reset
Brand new iPad 6th gen, day after set up I forgot the passcode and tried a hard reset while linked to iTunes. Now, when I try to turn it on I get an apple logo then screen turns black and is sort of backlit black. Any answers peeps??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Update: tried 3utools fully expecting to be returning the iPad within the next 24 hours, but the software worked to drag the iPad out of recovery mode, back to being locked out for forgetting the passcode & also having disowned it from my iCloud account out of spite
完成的
添加一条评论
1个答案
已选择的解决方案
Something might have gone wrong during restore, try restoring once more with iTunes and if it doesn’t work try also with 3Utools.
这个答案有帮助吗?
得分 4
3条评论:
Thank You arbaman!!
This partially worked, I was able to come out of the black screen and out of recovery mode but I still can’t remember the passcode and I deleted the iPad from my iCloud settings on my iPhone
完成的
The problem is that the computer is no good for restoring the iPad. As it appears to fail to start the restore.
I would recommend either taking it to apple to get it restored or use another computer if possible.
完成的
@benjamen50 It may well be..I, for instance, have always troubles to restore in DFU with a Mb Air, both with 3Utools and iTunes...heaven only knows why..error 2012, unable to kick it out from Dfu mode into restore, no problem with restore mode. Same setup on the Pros, no issue.
完成的
添加一条评论
添加你的答案
SD Card 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 1,318
