Keeps rebooting iPhone SE
I had problems with my iPhone like little lines on the screen when I would turn it on the home screen and sometimes I was unable to even put my passcode or typing would be really hard. The screen was not responsive. I decided to open the phone perhaps the connection was weak or something because that is what I read online about vertical lines so when I reconnected and tested it before putting it back, everything was fine. It was responsive and no vertical lines. However, when I actually started using it was not any better. Also while I was putting it back I tried putting this one big screw in all 4 holes where you connect the LCD because I had to know where that screw came from. However, it did not fit in any of them so I just let it go. Since it was not responsive I was like I wonder if something is wrong with my phone or just the LCD so I put my iPhones 5s LCD and it kept rebooting and I also put back the original iPhone SE LCD and it also keeps rebooting. I tried putting the SE LCD on iPhone 5s and it appears that it is not working very well and not responsive. Also it appears that there is a red dot in a white circle on the inside of the LCD on middle right.
I tried also putting the first 2 cables and not the cable to the right but it still rebooting.
