跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
iPhone 7 stuck on apple logo after screen replacement
I first replaced the screen and got a boot loop error.
When I connected the old, broken screen it worked fine and booted properly, so thought it was the new screen that was faulty.
I ordered another replacement screen and did the replacement but afterwards the setup just stayed on the apple logo indefinitely. I thought this screen was faulty as well so reconnected the original broken screen but the same thing was happening with that.
I read through a few forums saying it may be the camera flex cable that is broken, so I disconnected that and there was no change, still staying on the apple logo.
I have now bought another camera flex cable to double-check if that’s what is causing the error (I may have broken it during one of the replacements), but no success.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
I had this happen on an iPhone 7 Plus that I was working on. Double Check the connections from the screen going to the motherboard. Apparently one of the connections on the screen was not seated correctly and was causing the phone not to boot.
这个答案有帮助吗?
得分 0
1条评论:
I have pressed down reasonably hard on all the connections but that hasn't seemed to work.
完成的
添加一条评论
If all the cables are connected correctly, I’d try a new front camera flex just to be sure. 7s boot loop for pretty much any little issue, just try a couple things if you have parts around
这个答案有帮助吗?
得分 0
1条评论:
I have already tried this with no success.
完成的
添加一条评论
Did you disconnect the batter before repair and connect the battery last after the repair? This can happen if you have damaged the home button flex. Maybe the first screen was faulty but when transferring components to the new screen then you may have damaged it the home button flex. Another reason could be you somehow damaged the battery when repairing the screen however that isn’t very likely to happen.
这个答案有帮助吗?
得分 0
1条评论:
As I did the transfer between screens a few times I may not have disconnected the battery every time.
Also, before I bought the newer replacement screen I did manage to get the original screen to work without the home button flex connected, so I don't think it is that.
完成的
添加一条评论
添加你的答案
James Lloyd 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 135
