跳转到主内容
In 2012, Sony Entertainment announced that the company would be releasing a new version of its 2006 Playstation 3 console. The new console is call the Playstation 3 Super Slim and is identified by the model number, CECH-4000. The PlayStation 3 Super Slim (CECH400x) is the third version of the PS3 video game console produced by Sony Computer Entertainment. It was released October 25, 2012.
211 个问题 查看全部
My ps3 spins up a game disc but won’t read the disc.
I found a ps3 super slim at my work. ( I clean out mobile homes) all discs will spin up but only dvd’s, and cd’s will read. Blue ray movies and ps3 game discs won’t work. The internet and other forums said that a weak laser is to blame so I replaced that, made sure all the ribbon cables are fully seated, held the disc door closed so everything would spin up…and now it won’t read any kind of media. With games it will show the spin up symbol but not load it up. With cd’s it says loading error “check network settings” if you have any idea of what I need to fix/replace or try then hit me up. This is my last try at fixing this thing :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi @tactipants
Most likely the blu ray lens section is faulty.
Sadly seems it is quite common.
I had helped some of my family members in replacing the lens traverse mechanism part.
After some time of usage, maybe a couple of years, it failed again and have to repeat the procedure.
Not sure if it is due to bad part / quality or somewhat has caused this.
Based on the info provided by folks around….
you need to find the matching lens mechanism part to do replacement.
这个答案有帮助吗?
得分 2
7条评论:
I replaced the whole lens bay today with a new one. The metal tab with the two lenses and I made sure the part numbers matched. I said that in my post, thanks anyways!
完成的
Hi Lance, my mind is still booting up, lol
Is the lens replacement part correct / same with the existing one?
完成的
Yeah, it’s a KEM-850 PHA. The replacement drive is also a KEM-850 PHA and after visually comparing them they look exactly the same. I’m really stumped. After tinkering with it tonight, it spins up the disc a few times and sounds like a car shifting but never getting to a higher gear. After 5 attempts it quits and stops the disc. I’m really new at the electronics repair stuff so any help is better than what I have so far from YouTube and Google :)
完成的
@tactipants
Had you tried replacing back the previous one and try?
完成的
I haven’t yet, I’ll try that and check back in a few minutes, thanks for your quick responses!
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Lance Gaerte 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 45
总计 3,250
