跳转到主内容
The Wiko Pulp 4G is a mid segment smartphone with some good features and specifications. It has a 5" Display with a resolution of 1280x720, a 13MP camera and a 1.2 GHz QuadCore processor.
7 个问题 查看全部
Techno c8 doesn't charge.
Techno c8 only charges with a particular charger. Have tried different chargers at stores but it won't charge. It just stays at the same percentage. So I'm worried is it a motherboard problem ? And if so how do I go about it. Could it be broken contacts? A guide on troubleshooting and repairing such related problems would be welcome. Also , there's a caveat. Why is it that the phone charges well with just that one particular charger but rejects all other chargers twice as powerful ? Could it be the USB cable of the charger? So what are my options? Sorry it's long but I really need help on this. Thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@nathansteam “charges well with just that one particular charger but rejects all other chargers twice as powerful” not sure which other chargers you are using but their pinout could be different (different wiring). If it charges with one particular charger it is u likely that this is directly related to your phone. If so it will most likely be the charging port that is loose. Try the correct charger for your phone and tell us if it charges with that.
这个答案有帮助吗?
得分 2
添加一条评论
could just be a damaged socket
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nathan Swift 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 5
总计 158
