跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1199 个问题 查看全部
Glitchy screen after screen repair
About a week ago I replaced an iPhone X screen. Everything was working fine after the replacement. Two days later the screen started to glitch and just go black for a split second and go about life… The problem is still there and I’m not sure why. Can it be the screen is faulty maybe???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
6个答案
最有帮助的答案
Where did you get the screen, the touch panels on the copy oled, HO3 and LCD versions of the iphone X are the cheaper kind (you can see the easy digitizer in sunlight) are not very good.
There was a known issue with the iphone X causing touch problems after repair and this IIRC was a software update.
Try reseating the connectors and see if there is any bits of crud in the connectors on the motherboard.
it could very well be just a bad screen
这个答案有帮助吗?
得分 3
添加一条评论
I had the same problem, I sent the screen back and got a replacement. I haven’t had any graphical glitching with the new screen, so I would say it’s pretty safe to assume that the screen itself was faulty.
这个答案有帮助吗?
得分 1
添加一条评论
Try By hard resetting your iPhone, you’ll force it to abruptly turn off and back on. Sometimes crashed software can cause screen glitches, so restarting your iPhone may fix the problem.
这个答案有帮助吗?
得分 0
添加一条评论
I have the same issues, and it frustrates me because it interrupts my delivery routes. I was told by an expert that it could be a defective screen (the cheap kind) or that I need to clean most parts with a brush and electrical cleaner, but I hope it's a screen because it will take less time to replace than taking all the other parts out to clean it.
这个答案有帮助吗?
得分 0
添加一条评论
i got 2 screen iPhone x
from you i install first one not any issue ,but second one had flickering and turned iPhone to lock mode that said try to put screen pin 5 minutes later and so on....
i sent it back they gave me a new one but this one got the same problem..
这个答案有帮助吗?
得分 0
添加一条评论
Sometimes this happened’s when the screws are to tight. Make sure thy aren’t to tight.
这个答案有帮助吗?
得分 -1
2条评论:
how do you untighten them
完成的
@MaeTiny Lofton using the correct bit, twist slightly counter clockwise.
完成的
添加一条评论
添加你的答案
wm_alvarez 将永远感激不已
浏览统计数据:
过去 24 小时: 14
过去 7 天: 92
过去 30 天: 396
总计 8,038
