跳转到主内容
苹果AirPods是于2016年12月发布的无线耳机。
94 个问题 查看全部
Airpods pair with iPhone 6S Plus while in case
After I washed my Airpods in the laundry, not in dryer, I removed and let dry for a day. Now the Airpods regularly and randomly connect to my iPhone 6S Plus. iPhone displays the Airpods pop up tile when this happens. this happens when both pods are in the case with the case lid closed. This is causing connectivity issues with vehicle bluetooth connect to iPhone as I assume they are randomly connecting. Also the Airpods battery indicator is in a constant state of charging and the case battery is decreasing rapidly now. Down to 50% in 10 hours with 1-2 hours of Airpod use. Airpods seem to work and charge fine other wise. Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
It is possible that some of the power management circuitry in the AirPods got water damaged, as the AirPods is not IP rated. Did only the AirPods get washed, or did the case also get washed?
完成的
If its a bluetooth issue it's obviously the Airpods
完成的
@arthurshi the case and pods were washed.
完成的
Interesting. I think the case may be the damaged part rather than the AirPods, as it sounds like it is constantly initializing pairing (the pairing button may have shorted, or the hinge sensor). The case is also less sealed than the AirPods, so it may have been more susceptible to water damage.
Try connecting your AirPods with your iPhone without having your case close by. If it doesn't trigger the popup tiles, it may be the case.
If you have access to a different case (friends, Apple store?), try it with your AirPods to see if it's the issue.
Unfortunately, maybe both AirPods and case are damaged. Neither are repairable...but if it's the case, at least you can buy a replacement one separately.
完成的
添加一条评论
1个答案
已选择的解决方案
I would visit an Apple Store with your AirPod’s, the pod’s case and a USB cable see if they will allow you to try their pod case with your AirPod’s. If Apple Store’s pod’s case works with your AirPod’s you know you need a new case.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
jalarou 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 1,077
