跳转到主内容
Repair guides and support for Panasonic's Viera line of televisions.
383 个问题 查看全部
TV won’t turn on. Red light blinking17 times- Panasonic 4k 48inch
Hi guys,
TV is not switching on. Red light is blinking 17 times. After 3 blinks a pause then it blinks 14 times. It’s a 3 year old TV. Model TX-48CX400B 4k UHD.
Please help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Not finding a 17 blink code:
The exact error is represented by the number of blinks in each series of blinks. By using this fault error code,
you can diagnose the problem with the TV without even opening it.
First, be sure you are counting the blinks correctly – it is very important to correctly diagnosing the problem.
To do that, turn the TV OFF, and then back on and count the number of times the LED blinks.
Repeat the process to confirm and let us know.
这个答案有帮助吗?
得分 3
评论:
@mayer thanks for a quick reply. I was getting 17 blinks( 3 + 14) when I was trying to switch on the tv from the remote.
But if I just plug in the tv to the mains it's giving me 3 blinks and then the red light stays.
Does this make sense?
完成的
There's no code for 14 blinks. But the is for three, get this fixed first: 3 blinks 3.3v SOS D Board
完成的
Noted with thanks!
完成的
Mines giving me 3 then 13
Any help please
完成的
Here are the error codes for the Panasonic : https://finderrorcode.com/panasonic-tv-e...
完成的
添加一条评论
添加你的答案
Harvey 将永远感激不已
浏览统计数据:
过去的24小时: 2
过去的7天: 18
过去的30天: 31
总计 332
